Ir para o conteúdo principal
Zoomer Jurassic World Indominus Rex Eye LED Replacement
O que você precisa
  1. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: passo 1, imagem 1 %32 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: passo 1, imagem 2 %32
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 2, imagem 1 %32 Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 2, imagem 2 %32 Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 2, imagem 3 %32
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: passo 3, imagem 1 %32 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: passo 3, imagem 2 %32
    • Remove the four (4) 7.5mm Phillips screws from the pieces holding the circuit board for the LEDs in place.
    • Use tweezers to pull the circuit board out of place.
    • Pull directly upward! Be careful not to break the circuit board during removal.
  4. Zoomer Jurassic World Indominus Rex Eye LED Replacement: passo 4, imagem 1 %32
    • Use a soldering iron to disconnect the four (4) wires from the circuit board.
    • Soldering technique guide from iFixit can be found here.
    • Be careful not to burn yourself or the plastic while soldering!
Conclusão
Luke Selby
Membro desde: 01/20/16
624 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 10-3, Remmell Spring 2016 Membro de USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 350
