Ir para o conteúdo principal
Zoomer Dino Boomer Nose Sensor Replacement
O que você precisa
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: passo 1, imagem 1 %32 Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: passo 1, imagem 2 %32
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: passo 2, imagem 1 %32 Zoomer Dino Boomer Nose Sensor Replacement: passo 2, imagem 2 %32
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: passo 3, imagem 1 %32 Zoomer Dino Boomer Nose Sensor Replacement: passo 3, imagem 2 %32
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: passo 4, imagem 1 %32 Zoomer Dino Boomer Nose Sensor Replacement: passo 4, imagem 2 %32
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: passo 5, imagem 1 %32 Zoomer Dino Boomer Nose Sensor Replacement: passo 5, imagem 2 %32 Zoomer Dino Boomer Nose Sensor Replacement: passo 5, imagem 3 %32
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: passo 6, imagem 1 %32
    • Remove and replace the nose sensor.
Conclusão
Lauren Mannix
Membro desde: 08/29/15
398 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-1, Wollert Fall 2015 Membro de USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 1,336
