Ir para o conteúdo principal
Zoomer Dino Boomer Back Button Replacement
O que você precisa
    1. Zoomer Dino Boomer Back Button Replacement, Back Cover: passo 1, imagem 1 %32
      • Power off Zoomer Dino Boomer before disassembly.
      • Remove the eight 9.3mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. Zoomer Dino Boomer Back Button Replacement: passo 2, imagem 1 %32 Zoomer Dino Boomer Back Button Replacement: passo 2, imagem 2 %32
      • Turn dinosaur over and hold upright.
      • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
      • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
      Pergunte ao FixBot
      Comentar
    3. Zoomer Dino Boomer Back Button Replacement: passo 3, imagem 1 %32 Zoomer Dino Boomer Back Button Replacement: passo 3, imagem 2 %32 Zoomer Dino Boomer Back Button Replacement: passo 3, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
      • Remove back cover.
      • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
      • Do not damage the wires or circuit board.
      Pergunte ao FixBot
      Comentar
    1. Zoomer Dino Boomer Back Button Replacement, Back Button: passo 4, imagem 1 %32
      • Where the button is largest, squeeze the two white tabs together.
      Pergunte ao FixBot
      Comentar
    2. Zoomer Dino Boomer Back Button Replacement: passo 5, imagem 1 %32
      • Push in the white circular piece between these tabs as far as it will go.
      Pergunte ao FixBot
      Comentar
    3. Zoomer Dino Boomer Back Button Replacement: passo 6, imagem 1 %32 Zoomer Dino Boomer Back Button Replacement: passo 6, imagem 2 %32
      • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
      • Remove the back button.
      Pergunte ao FixBot
      Comentar
Conclusão
Lauren Mannix
Membro desde: 08/29/15
398 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-1, Wollert Fall 2015 Membro de USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 47
Ao todo: 2,568
