Ir para o conteúdo principal
Zoom H1 Handy Recorder USB Port Replacement
O que você precisa
  1. Zoom H1 Handy Recorder USB Port Replacement, USB Port: passo 1, imagem 1 %32
    • Turn the device over with its display down.
    Pergunte ao FixBot
    Comentar
  2. Zoom H1 Handy Recorder USB Port Replacement: passo 2, imagem 1 %32
    • Remove the battery cover, pressing down on the tabs and sliding.
    Pergunte ao FixBot
    Comentar
  3. Zoom H1 Handy Recorder USB Port Replacement: passo 3, imagem 1 %32
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
    Pergunte ao FixBot
    Comentar
  4. Zoom H1 Handy Recorder USB Port Replacement: passo 4, imagem 1 %32
    • Carefully pry up the top end of the back cover using one finger.
    Pergunte ao FixBot
    Comentar
  5. Zoom H1 Handy Recorder USB Port Replacement: passo 5, imagem 1 %32
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
    Pergunte ao FixBot
    Comentar
  6. Zoom H1 Handy Recorder USB Port Replacement: passo 6, imagem 1 %32
    • Unscrew the circuit board screw.
    • This screw is located down near the bottom of the device on the blue circuit board. It is just to the right of the USB port.
    Pergunte ao FixBot
    Comentar
  7. Zoom H1 Handy Recorder USB Port Replacement: passo 7, imagem 1 %32
    • Use a plastic removal tool to disconnect the blue circuit board from the green circuit board underneath.
    Pergunte ao FixBot
    Comentar
  8. Zoom H1 Handy Recorder USB Port Replacement: passo 8, imagem 1 %32
    • Turn the circuit board on its side to reveal the USB soldering points.
    Pergunte ao FixBot
    Comentar
  9. Zoom H1 Handy Recorder USB Port Replacement: passo 9, imagem 1 %32
    • De-solder the USB port from its four soldering points.
    • Be careful not to damage the wire connected to the USB port during de-soldering.
    Pergunte ao FixBot
    Comentar
  10. Zoom H1 Handy Recorder USB Port Replacement: passo 10, imagem 1 %32
    • Place the new USB port in the same spot on the board, and re-solder at each of the four points.
    • Ensure you re-solder the wire into the same connection you removed it from during desoldering
    Pergunte ao FixBot
    Comentar
  11. Zoom H1 Handy Recorder USB Port Replacement: passo 11, imagem 1 %32
    • Rotate the circuit board back to its initial position, with the port on the underside of the board.
    Pergunte ao FixBot
    Comentar
  12. Zoom H1 Handy Recorder USB Port Replacement: passo 12, imagem 1 %32
    • Replace the circuit board screw.
    Pergunte ao FixBot
    Comentar
Conclusão
Alex
Membro desde: 10/28/13
809 Reputação
Autoria de 5 guias
3Comentários do guia
the third screw is on the outside of the case, the same place
xhbang - Responder Compartilhar
This is awesome. Do you know if I can switch the port for USB-C?
Regan Ryan - Responder Compartilhar
What USB Port do i need to get?
Ricky Smith - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 60
Ao todo: 6,331
