Ir para o conteúdo principal
Zoom H1 Handy Recorder Battery Terminal Replacement
O que você precisa
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: passo 1, imagem 1 %32
    • Place the device so the display is down.
    Pergunte ao FixBot
    Comentar
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 2, imagem 1 %32
    • Remove the battery cover, pressing down on the tabs and sliding.
    Pergunte ao FixBot
    Comentar
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 3, imagem 1 %32
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
    Pergunte ao FixBot
    Comentar
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 4, imagem 1 %32
    • Carefully pry up the top end of the back cover using one finger
    Pergunte ao FixBot
    Comentar
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 5, imagem 1 %32
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
    Pergunte ao FixBot
    Comentar
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 6, imagem 1 %32
    • De-solder at terminal point one.
    Pergunte ao FixBot
    Comentar
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 7, imagem 1 %32
    • De-solder at the second terminal point.
    Pergunte ao FixBot
    Comentar
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 8, imagem 1 %32 Zoom H1 Handy Recorder Battery Terminal Replacement: passo 8, imagem 2 %32
    • Remove the faulty terminals
    Pergunte ao FixBot
    Comentar
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 9, imagem 1 %32
    • Place new lead in at point one and re-solder at the point.
    Pergunte ao FixBot
    Comentar
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 10, imagem 1 %32
    • Place second lead at point 2 and re-solder.
    Pergunte ao FixBot
    Comentar
Conclusão
To Re-construct device, perform these steps in reverse order.
Alex
Membro desde: 10/28/13
809 Reputação
Autoria de 5 guias
7Comentários do guia
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Responder Compartilhar
Mine has third screw under the serial-number sticker.
halluciana - Responder Compartilhar
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Responder Compartilhar
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Responder Compartilhar
Same problem, without any reason it is dead
eevilcute - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 69
Ao todo: 7,377
