Ir para o conteúdo principal
Zipper Stop Replacement
O que você precisa
    1. Zipper Stop Replacement, Stop: passo 1, imagem 1 %32
      • Evaluate the damage and examine the zipper for any indications of fracture, misalignment, or looseness.
      Pergunte ao FixBot
      Comentar
    2. Zipper Stop Replacement: passo 2, imagem 1 %32
      • Align the zipper stop so the post is on the same side as the zipper slider.
      Pergunte ao FixBot
      Comentar
    3. Zipper Stop Replacement: passo 3, imagem 1 %32
      • Gently place the stop beneath the zipper teeth.
      Pergunte ao FixBot
      Comentar
    4. Zipper Stop Replacement: passo 4, imagem 1 %32 Zipper Stop Replacement: passo 4, imagem 2 %32
      • After the stop has been positioned appropriately, clamp it in place with the needle nose pliers.
      • To ensure a snug fit, use firm pressure at multiple points to clamp the stop tightly around the zipper teeth.
      Pergunte ao FixBot
      Comentar
    5. Zipper Stop Replacement: passo 5, imagem 1 %32
      • To make sure the stop is firmly attached to the zipper track, gently tug on it after clamping it. Reclamp the stop if needed.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Dejia P.
Membro desde: 02/20/24
121 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 98
Ao todo: 2,511
