Ir para o conteúdo principal
Zerodate T26 USB-C Port Replacement
O que você precisa
  1. Zerodate T26 USB-C Port Replacement, Scroll Wheel: passo 1, imagem 1 %32 Zerodate T26 USB-C Port Replacement, Scroll Wheel: passo 1, imagem 2 %32
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 USB-C Port Replacement: passo 2, imagem 1 %32 Zerodate T26 USB-C Port Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 USB-C Port Replacement: passo 3, imagem 1 %32 Zerodate T26 USB-C Port Replacement: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 USB-C Port Replacement: passo 4, imagem 1 %32 Zerodate T26 USB-C Port Replacement: passo 4, imagem 2 %32
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 USB-C Port Replacement: passo 5, imagem 1 %32 Zerodate T26 USB-C Port Replacement: passo 5, imagem 2 %32
    • Remove the scroll wheel by pushing it to the right and pulling up.
  6. Zerodate T26 USB-C Port Replacement, USB-C Port: passo 6, imagem 1 %32 Zerodate T26 USB-C Port Replacement, USB-C Port: passo 6, imagem 2 %32 Zerodate T26 USB-C Port Replacement, USB-C Port: passo 6, imagem 3 %32
    • Take out the battery obstructing movement. This should now allow you to gently pull the circuit board up from the bottom of the mouse.
    • Please be very careful when pulling up the circuit board! Yanking it out could result in further damage to the mouse. Make sure you go slow and steady!
  7. Zerodate T26 USB-C Port Replacement: passo 7, imagem 1 %32
    • De-solder the charging port at one end of the mouse, in order to carefully remove it for a replacement.
    • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove any circuitry. In order to keep yourself safe and your mouse undamaged, please follow the guide found here to learn to properly solder.
Conclusão
Janice Rullan
Membro desde: 03/13/23
662 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 338
