Ir para o conteúdo principal
Zeki TBQG884B Motherboard Replacement
O que você precisa
  1. Zeki TBQG884B Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Zeki TBQG884B Motherboard Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Motherboard Replacement: passo 2, imagem 1 %32
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Motherboard Replacement: passo 3, imagem 1 %32 Zeki TBQG884B Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B Motherboard Replacement: passo 5, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B Motherboard Replacement: passo 6, imagem 1 %32
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
Conclusão
Linlin Cai
Membro desde: 09/16/15
317 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-3, Harley Fall 2015 Membro de IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 501
