Ir para o conteúdo principal
Zeki Droid Tablet Front Screen Replacement
O que você precisa
    1. Zeki Droid Tablet Front Screen Replacement, Back Casing: passo 1, imagem 1 %32
      • Remove the back casing by slowly popping each tab out with a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    2. Zeki Droid Tablet Front Screen Replacement: passo 2, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Remove the tapes one by one from the connecting wires with tweezers.
      Pergunte ao FixBot
      Comentar
    3. Zeki Droid Tablet Front Screen Replacement: passo 3, imagem 1 %32
      • Remove the black clips from both sides of the casing with a plastic opening tool.
      • The clips should pop off separate from the speakers.
      Pergunte ao FixBot
      Comentar
    4. Zeki Droid Tablet Front Screen Replacement: passo 4, imagem 1 %32
      • Remove the speakers from the back casing.
      • Do not tug on the speakers because they are connected to fragile wires.
      Pergunte ao FixBot
      Comentar
    5. Zeki Droid Tablet Front Screen Replacement: passo 5, imagem 1 %32
      • Pull the speakers away from the back casing carefullly.
      Pergunte ao FixBot
      Comentar
    1. Zeki Droid Tablet Front Screen Replacement, Front Screen: passo 6, imagem 1 %32
      • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Zeki Droid Tablet Front Screen Replacement: passo 7, imagem 1 %32
      • Lift the camera and flash components from their fittings using tweezers.
      Pergunte ao FixBot
      Comentar
    3. Zeki Droid Tablet Front Screen Replacement: passo 8, imagem 1 %32
      • Lift the metal framing to reach the components at the front of the device.
      • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
      Pergunte ao FixBot
      Comentar
    4. Zeki Droid Tablet Front Screen Replacement: passo 9, imagem 1 %32 Zeki Droid Tablet Front Screen Replacement: passo 9, imagem 2 %32
      • Push the screen forward to remove.
      Pergunte ao FixBot
      Comentar
Conclusão
Kyla
Membro desde: 03/11/15
156 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 569
