Ir para o conteúdo principal
Zeki Droid Tablet Camera Replacement
O que você precisa
    1. Zeki Droid Tablet Camera Replacement, Back Casing: passo 1, imagem 1 %32
      • Remove the back casing by slowly popping each tab out with a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    2. Zeki Droid Tablet Camera Replacement: passo 2, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Remove the tapes one by one from the connecting wires with tweezers.
      Pergunte ao FixBot
      Comentar
    3. Zeki Droid Tablet Camera Replacement: passo 3, imagem 1 %32
      • Remove the black clips from both sides of the casing with a plastic opening tool.
      • The clips should pop off separate from the speakers.
      Pergunte ao FixBot
      Comentar
    4. Zeki Droid Tablet Camera Replacement: passo 4, imagem 1 %32
      • Remove the speakers from the back casing.
      • Do not tug on the speakers because they are connected to fragile wires.
      Pergunte ao FixBot
      Comentar
    5. Zeki Droid Tablet Camera Replacement: passo 5, imagem 1 %32
      • Pull the speakers away from the back casing carefullly.
      Pergunte ao FixBot
      Comentar
    1. Zeki Droid Tablet Camera Replacement, Camera: passo 6, imagem 1 %32 Zeki Droid Tablet Camera Replacement, Camera: passo 6, imagem 2 %32
      • Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
      • The adhesive may make it difficult to remove the cameras from the tablet.
      Pergunte ao FixBot
      Comentar
    2. Zeki Droid Tablet Camera Replacement: passo 7, imagem 1 %32
      • Undo the ZIF connector that is connecting the cameras to the motherboard using a plastic spudger or fingernail.
      • This guide has more information on how to undo the ZIF connector
      • Do not yank the ZIF connector. It should come apart very easily with little force needed.
      Pergunte ao FixBot
      Comentar
    3. Zeki Droid Tablet Camera Replacement: passo 8, imagem 1 %32
      • Pull the copper connection carefully away from the motherboard of the tablet to completely remove the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 29
Ao todo: 652
