Ir para o conteúdo principal
Zebra ZP 450 Power Switch Replacement
O que você precisa
  1. Zebra ZP 450 Power Switch Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Power Switch Replacement: passo 2, imagem 1 %32
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Power Switch Replacement: passo 3, imagem 1 %32
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Power Switch Replacement: passo 4, imagem 1 %32 Zebra ZP 450 Power Switch Replacement: passo 4, imagem 2 %32 Zebra ZP 450 Power Switch Replacement: passo 4, imagem 3 %32
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
  5. Zebra ZP 450 Power Switch Replacement, Power Switch: passo 5, imagem 1 %32
    • Using the soldering iron, unsolder the joints on the back of the motherboard connecting the power switch to the motherboard.
    • For more information on proper soldering technique, please visit the How to Solder and Desolder Connections guide.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 170
