Ir para o conteúdo principal
ZTE Whirl 2 Screen Replacement
O que você precisa
  1. ZTE Whirl 2 Screen Replacement, Battery: passo 1, imagem 1 %32 ZTE Whirl 2 Screen Replacement, Battery: passo 1, imagem 2 %32 ZTE Whirl 2 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
  2. ZTE Whirl 2 Screen Replacement: passo 2, imagem 1 %32 ZTE Whirl 2 Screen Replacement: passo 2, imagem 2 %32 ZTE Whirl 2 Screen Replacement: passo 2, imagem 3 %32
    • Pry the battery from the phone using your fingers.
  3. ZTE Whirl 2 Screen Replacement, Back Panel: passo 3, imagem 1 %32 ZTE Whirl 2 Screen Replacement, Back Panel: passo 3, imagem 2 %32 ZTE Whirl 2 Screen Replacement, Back Panel: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
  4. ZTE Whirl 2 Screen Replacement: passo 4, imagem 1 %32 ZTE Whirl 2 Screen Replacement: passo 4, imagem 2 %32 ZTE Whirl 2 Screen Replacement: passo 4, imagem 3 %32
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
  5. ZTE Whirl 2 Screen Replacement: passo 5, imagem 1 %32
    • Remove the midframe from the digitizer.
  6. ZTE Whirl 2 Screen Replacement, Screen: passo 6, imagem 1 %32 ZTE Whirl 2 Screen Replacement, Screen: passo 6, imagem 2 %32
    • Use tweezers to pull the lock button and volume stickers out from the side panels.
    • Use the iFixit Opening Tool to unlock the ribbon connector above the camera. Pull the ribbon from the connector.
  7. ZTE Whirl 2 Screen Replacement: passo 7, imagem 1 %32
    • Use a spudger tool to unlock the screen ribbon cable.
    • Pull the ribbon cable from the connecter with a pair of tweezers.
  8. ZTE Whirl 2 Screen Replacement: passo 8, imagem 1 %32 ZTE Whirl 2 Screen Replacement: passo 8, imagem 2 %32 ZTE Whirl 2 Screen Replacement: passo 8, imagem 3 %32
    • Remove the motherboard to access the screen. Lift the screen away from the front cover and replace.
Conclusão
Molli Reeder
Membro desde: 02/04/20
97 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 Membro de UW Stout, Team S1-G1, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 269
