Ir para o conteúdo principal
ZTE Maven 3 Screen Replacement
O que você precisa
  1. ZTE Maven 3 Screen Replacement, Back Cover: passo 1, imagem 1 %32 ZTE Maven 3 Screen Replacement, Back Cover: passo 1, imagem 2 %32 ZTE Maven 3 Screen Replacement, Back Cover: passo 1, imagem 3 %32
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
    Pergunte ao FixBot
    Comentar
  2. ZTE Maven 3 Screen Replacement, Battery: passo 2, imagem 1 %32 ZTE Maven 3 Screen Replacement, Battery: passo 2, imagem 2 %32 ZTE Maven 3 Screen Replacement, Battery: passo 2, imagem 3 %32
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
    Pergunte ao FixBot
    Comentar
  3. ZTE Maven 3 Screen Replacement, Midframe: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
    Pergunte ao FixBot
    Comentar
  4. ZTE Maven 3 Screen Replacement: passo 4, imagem 1 %32
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
    Pergunte ao FixBot
    Comentar
  5. ZTE Maven 3 Screen Replacement: passo 5, imagem 1 %32 ZTE Maven 3 Screen Replacement: passo 5, imagem 2 %32
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
    Pergunte ao FixBot
    Comentar
  6. ZTE Maven 3 Screen Replacement, Motherboard: passo 6, imagem 1 %32
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
    Pergunte ao FixBot
    Comentar
  7. ZTE Maven 3 Screen Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
    Pergunte ao FixBot
    Comentar
  8. ZTE Maven 3 Screen Replacement: passo 8, imagem 1 %32 ZTE Maven 3 Screen Replacement: passo 8, imagem 2 %32
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
    Pergunte ao FixBot
    Comentar
  9. ZTE Maven 3 Screen Replacement: passo 9, imagem 1 %32 ZTE Maven 3 Screen Replacement: passo 9, imagem 2 %32 ZTE Maven 3 Screen Replacement: passo 9, imagem 3 %32
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
    Pergunte ao FixBot
    Comentar
  10. ZTE Maven 3 Screen Replacement: passo 10, imagem 1 %32 ZTE Maven 3 Screen Replacement: passo 10, imagem 2 %32
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
    Pergunte ao FixBot
    Comentar
  11. ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: passo 11, imagem 1 %32 ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: passo 11, imagem 2 %32
    • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
    Pergunte ao FixBot
    Comentar
  12. ZTE Maven 3 Screen Replacement, Screen: passo 12, imagem 1 %32
    • What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
    Pergunte ao FixBot
    Comentar
Conclusão
Emma Thiboutot
Membro desde: 10/30/23
705 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 316
