Ir para o conteúdo principal
ZTE Maven 3 SIM Card Replacement
O que você precisa
  1. ZTE Maven 3 SIM Card Replacement, Back Cover: passo 1, imagem 1 %32 ZTE Maven 3 SIM Card Replacement, Back Cover: passo 1, imagem 2 %32 ZTE Maven 3 SIM Card Replacement, Back Cover: passo 1, imagem 3 %32
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
    Pergunte ao FixBot
    Comentar
  2. ZTE Maven 3 SIM Card Replacement, SIM Card: passo 2, imagem 1 %32
    • Locate the SIM Card slot on the upper left middle of the phone.
    • Remove the SIM card carefully from the back of the phone by gently sliding the card up and lifting it. Put the SIM to the side.
    • Gently pop in the new sim card where the old one was just removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Emma Thiboutot
Membro desde: 10/30/23
705 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 286
