Ir para o conteúdo principal
ZTE Grand X Max Plus Back Cover Replacement
O que você precisa
  1. ZTE Grand X Max Plus Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
    Pergunte ao FixBot
    Comentar
  2. ZTE Grand X Max Plus Back Cover Replacement: passo 2, imagem 1 %32 ZTE Grand X Max Plus Back Cover Replacement: passo 2, imagem 2 %32
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
    Pergunte ao FixBot
    Comentar
  3. ZTE Grand X Max Plus Back Cover Replacement: passo 3, imagem 1 %32 ZTE Grand X Max Plus Back Cover Replacement: passo 3, imagem 2 %32
    • Carefully remove the cover from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Jordano Baer
Membro desde: 10/02/17
716 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S9-G4, Remmell Fall 2017 Membro de USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Membros
Autoria de 10 guias
1Comentário do guia
There seems to be an antenna attached to the mid frame that gets stuck to the back glass on the top left. Does anyone know what this is??
Kiki Jade - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 26
Ao todo: 731
