Ir para o conteúdo principal
ZTE Compel Camera Replacement
O que você precisa
  1. ZTE Compel Camera Replacement, Battery: passo 1, imagem 1 %32
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. ZTE Compel Camera Replacement: passo 2, imagem 1 %32
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
    Pergunte ao FixBot
    Comentar
  3. ZTE Compel Camera Replacement: passo 3, imagem 1 %32
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
    Pergunte ao FixBot
    Comentar
  4. ZTE Compel Camera Replacement, Camera: passo 4, imagem 1 %32 ZTE Compel Camera Replacement, Camera: passo 4, imagem 2 %32
    • Remove the 9 screws that measure 4 mm Phillips #000.
    • Use your iFixit Magnetic Project Mat, or any magnetic surface, to hold your removed screws while working on your ZTE Compel.
    Pergunte ao FixBot
    Comentar
  5. ZTE Compel Camera Replacement: passo 5, imagem 1 %32 ZTE Compel Camera Replacement: passo 5, imagem 2 %32 ZTE Compel Camera Replacement: passo 5, imagem 3 %32
    • Notice the crease in the shiny black plastic. Insert the flat end of your spudger here, about 3mm above the volume buttons, and work your spudger around the circumference of the phone until the front and back are separated.
    Pergunte ao FixBot
    Comentar
  6. ZTE Compel Camera Replacement: passo 6, imagem 1 %32 ZTE Compel Camera Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the camera by placing your tweezers on the gold piece attached to camera and lift up, disconnecting from the motherboard.
    • Grip the camera with your tweezers and lift up to remove the camera.
    • May need to use light force to remove camera due to the adhesive on the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Ohio State, Team S1-G4, Whitney Fall 2018 Membro de Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 35
Ao todo: 499
