Ir para o conteúdo principal
ZTE Compel Battery Replacement
O que você precisa
  1. ZTE Compel Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. ZTE Compel Battery Replacement: passo 2, imagem 1 %32
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
    Pergunte ao FixBot
    Comentar
  3. ZTE Compel Battery Replacement: passo 3, imagem 1 %32
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
    Pergunte ao FixBot
    Comentar
Conclusão
Kidron Stamper
Membro desde: 09/06/18
327 Reputação
Autoria de 3 guias
Equipe
Ohio State, Team S1-G4, Whitney Fall 2018 Membro de Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 480
