Ir para o conteúdo principal
ZTE Boost MAX N9520 Battery Replacement
O que você precisa
  1. ZTE Boost MAX N9520 Battery Replacement, Battery: passo 1, imagem 1 %32 ZTE Boost MAX N9520 Battery Replacement, Battery: passo 1, imagem 2 %32
    • First, remove the microSD tray, use a sim ejector tool for this.
    • Begin by removing the upper and lower plastic panels. Pry the top with a spudger from the corners as shown in the red circle.
    • Remove the SIM card.
    • Next pry off the lower plastic panel. This one is stuck on a little bit more.
Conclusão
5 outras pessoas executaram este guia.
Um comentário
An additional more comprehensive wiki troubleshooting guide for the ZTE Max …compiled by a team of students here on “IFIXIT” that I recently discovered that you may also find helpful.
ZTE Max XL Troubleshooting
Jason Thompson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 3,070
