Ir para o conteúdo principal
ZTE Blade X Max Back Cover Replacement
O que você precisa
  1. ZTE Blade X Max Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 ZTE Blade X Max Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
    • It will take about ten minutes for the adhesive to be heated enough to remove the backing.
    • You will have to reheat the iOpener or heating pad a few times.
    Pergunte ao FixBot
  2. ZTE Blade X Max Back Cover Replacement: passo 2, imagem 1 %32 ZTE Blade X Max Back Cover Replacement: passo 2, imagem 2 %32 ZTE Blade X Max Back Cover Replacement: passo 2, imagem 3 %32
    • Slide the Jimmy along the under backing and lightly push the plastic up.
    • You will hear a snapping sound as you slide the Jimmy along the backing. This is from the closures releasing. There should be seven total closures on either side of the device, and three on the top and bottom.
    Pergunte ao FixBot
  3. ZTE Blade X Max Back Cover Replacement: passo 3, imagem 1 %32
    • Carefully remove the backing from the phone once the closures are released.
    • If you do not open all of the closures on the backing do not attempt to pry it off.
    • Be careful when opening the back of the phone. The fingerprint scanner is connected by a thin film that will tear if pulled too roughly.
    Pergunte ao FixBot
  4. ZTE Blade X Max Back Cover Replacement: passo 4, imagem 1 %32 ZTE Blade X Max Back Cover Replacement: passo 4, imagem 2 %32 ZTE Blade X Max Back Cover Replacement: passo 4, imagem 3 %32
    • Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
    Pergunte ao FixBot
  5. ZTE Blade X Max Back Cover Replacement: passo 5, imagem 1 %32 ZTE Blade X Max Back Cover Replacement: passo 5, imagem 2 %32 ZTE Blade X Max Back Cover Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
    • Use the tweezers to remove the panel.
    Pergunte ao FixBot
  6. ZTE Blade X Max Back Cover Replacement: passo 6, imagem 1 %32 ZTE Blade X Max Back Cover Replacement: passo 6, imagem 2 %32
    • Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 37
Ao todo: 1,025
