Ir para o conteúdo principal
ZTE Blade E Front Panel Replacement
O que você precisa
  1. ZTE Blade E Front Panel Replacement, Motherboard: passo 1, imagem 1 %32
    • Using a spudger, remove the back panel of the phone.
    Pergunte ao FixBot
    Comentar
  2. ZTE Blade E Front Panel Replacement: passo 2, imagem 1 %32 ZTE Blade E Front Panel Replacement: passo 2, imagem 2 %32
    • Remove the battery and SD card from the phone.
    Pergunte ao FixBot
    Comentar
  3. ZTE Blade E Front Panel Replacement: passo 3, imagem 1 %32
    • Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
    Pergunte ao FixBot
    Comentar
  4. ZTE Blade E Front Panel Replacement: passo 4, imagem 1 %32
    • Remove the back piece, exposing the motherboard.
    Pergunte ao FixBot
    Comentar
  5. ZTE Blade E Front Panel Replacement: passo 5, imagem 1 %32 ZTE Blade E Front Panel Replacement: passo 5, imagem 2 %32 ZTE Blade E Front Panel Replacement: passo 5, imagem 3 %32
    • Flip up the three small tan clips holding the ribbons in place.
    Pergunte ao FixBot
    Comentar
  6. ZTE Blade E Front Panel Replacement: passo 6, imagem 1 %32
    • Gently slide each of the three ribbons out of the motherboard.
    Pergunte ao FixBot
    Comentar
  7. ZTE Blade E Front Panel Replacement: passo 7, imagem 1 %32
    • Slide the motherboard off of the ribbons detaching it from the front of the phone.
    Pergunte ao FixBot
    Comentar
  8. ZTE Blade E Front Panel Replacement, Front Panel: passo 8, imagem 1 %32
    • Carefully use the spudger to free the screen from the front panel. You can use your hands to pull it the rest of the way out once you have freed the screen from the clips.
    Pergunte ao FixBot
    Comentar
  9. ZTE Blade E Front Panel Replacement: passo 9, imagem 1 %32
    • Dispose of the old font panel and replace it with the new one.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 9-5, Leahy Fall 2014 Membro de USF Tampa, Team 9-5, Leahy Fall 2014
USFT-LEAHY-F14S9G5
3 Membros
Autoria de 10 guias
2Comentários do guia
I have the blade max .It's not even a month old and it won't charge it won't turn on ot is a crap Ola phone .So I take it bk to cricket ,well they can replace it ,I have to send it off wait a few days and they return me my phone.Why in the name of creation can't your stores replace them .Why did I pay good money to send it bk and be without a phone for several days,why because your a crappy company and I need my phone..
Laura Henderson - Responder Compartilhar
Matter a fact this is my second non functioning ZTE phone. Crap Ola phone..
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 42
Ao todo: 6,327
