Introdução
Speakers can become damaged in many ways from both use and exposure to things like water. To replace these speakers requires a near full disassembly of the device but is a relatively easy process to follow through with. Follow this guide to replace the speakers of your ZTE Axon 7 smartphone.
Speakers provide sound by converting an electrical signal to sound by using magnets to vibrate a flexible cone inside of an acoustic chamber. This vibration creates the sound waves that your ears hear.
Before beginning this repair, power off your phone and make sure it's disconnected from the charger.
O que você precisa
Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
Ferramenta utilizada nesse passo:Tweezers$3.99
Use a Phillips #00 screwdriver to remove the 2.0 mm screw securing the bracket at the top of the battery.
Use the angled tweezers to slide the top bracket up and off the phone.
