Ir para o conteúdo principal
ZTE Awe Screen Replacement
O que você precisa
  1. ZTE Awe Screen Replacement, Detach the mid frame: passo 1, imagem 1 %32
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
    Pergunte ao FixBot
    Comentar
  2. ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: passo 2, imagem 1 %32 ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: passo 2, imagem 2 %32 ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: passo 2, imagem 3 %32
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
    Pergunte ao FixBot
    Comentar
  3. ZTE Awe Screen Replacement, Expose the motherboard: passo 3, imagem 1 %32 ZTE Awe Screen Replacement, Expose the motherboard: passo 3, imagem 2 %32
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
    Pergunte ao FixBot
    Comentar
  4. ZTE Awe Screen Replacement, Remove the ribbon wires: passo 4, imagem 1 %32 ZTE Awe Screen Replacement, Remove the ribbon wires: passo 4, imagem 2 %32 ZTE Awe Screen Replacement, Remove the ribbon wires: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the four ribbon wires on the sides of the device.
    Pergunte ao FixBot
    Comentar
  5. ZTE Awe Screen Replacement, Orient the motherboard: passo 5, imagem 1 %32
    • Orient the motherboard to expose the mid frame.
    Pergunte ao FixBot
    Comentar
  6. ZTE Awe Screen Replacement, Remove the connector: passo 6, imagem 1 %32 ZTE Awe Screen Replacement, Remove the connector: passo 6, imagem 2 %32 ZTE Awe Screen Replacement, Remove the connector: passo 6, imagem 3 %32
    • Remove the connector to free the motherboard from the screen.
    Pergunte ao FixBot
    Comentar
  7. ZTE Awe Screen Replacement, Remove the cover: passo 7, imagem 1 %32
    • Remove the back cover from the phone.
    Pergunte ao FixBot
    Comentar
  8. ZTE Awe Screen Replacement, Remove battery: passo 8, imagem 1 %32
    • Pry the battery up and out of the phone.
    Pergunte ao FixBot
    Comentar
  9. ZTE Awe Screen Replacement: passo 9, imagem 1 %32 ZTE Awe Screen Replacement: passo 9, imagem 2 %32 ZTE Awe Screen Replacement: passo 9, imagem 3 %32
    • Gently wedge the spudger in between the glass screen and the mid frame.
    Pergunte ao FixBot
    Comentar
  10. ZTE Awe Screen Replacement, Separate the motherboard from the screen: passo 10, imagem 1 %32 ZTE Awe Screen Replacement, Separate the motherboard from the screen: passo 10, imagem 2 %32
    • Carefully pry the screen away from the motherboard.
    Pergunte ao FixBot
    Comentar
  11. ZTE Awe Screen Replacement, Remove the ribbons: passo 11, imagem 1 %32 ZTE Awe Screen Replacement, Remove the ribbons: passo 11, imagem 2 %32 ZTE Awe Screen Replacement, Remove the ribbons: passo 11, imagem 3 %32
    • Be careful when removing the ribbon wires. They are delicate.
    Pergunte ao FixBot
    Comentar
  12. ZTE Awe Screen Replacement, Remove the remaining ribbons: passo 12, imagem 1 %32 ZTE Awe Screen Replacement, Remove the remaining ribbons: passo 12, imagem 2 %32 ZTE Awe Screen Replacement, Remove the remaining ribbons: passo 12, imagem 3 %32
    • Remove the remaining two ribbon wires from their connectors.
    Pergunte ao FixBot
    Comentar
  13. ZTE Awe Screen Replacement, Expose the digitizer: passo 13, imagem 1 %32 ZTE Awe Screen Replacement, Expose the digitizer: passo 13, imagem 2 %32 ZTE Awe Screen Replacement, Expose the digitizer: passo 13, imagem 3 %32
    • Wedge the plastic spudger between the screen and the digitizer.
    • Gently pry apart the screen from the digitizer.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Jennifer DeMeo
Membro desde: 10/07/14
1.035 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-2, Leahy Fall 2014 Membro de USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 14,623
