Ir para o conteúdo principal
ZD-N Plus Wireless Controller Battery Replacement
O que você precisa
  1. ZD-N Plus Wireless Controller Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
    Pergunte ao FixBot
    Comentar
  2. ZD-N Plus Wireless Controller Battery Replacement: passo 2, imagem 1 %32 ZD-N Plus Wireless Controller Battery Replacement: passo 2, imagem 2 %32
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
    Pergunte ao FixBot
    Comentar
  3. ZD-N Plus Wireless Controller Battery Replacement, Battery: passo 3, imagem 1 %32
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
    Pergunte ao FixBot
    Comentar
  4. ZD-N Plus Wireless Controller Battery Replacement: passo 4, imagem 1 %32 ZD-N Plus Wireless Controller Battery Replacement: passo 4, imagem 2 %32
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
    Pergunte ao FixBot
    Comentar
  5. ZD-N Plus Wireless Controller Battery Replacement: passo 5, imagem 1 %32 ZD-N Plus Wireless Controller Battery Replacement: passo 5, imagem 2 %32
    • Remove the battery from the controller.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 69
Ao todo: 842
