Introdução
If you need to install or replace new wheels in your ZCWA BR151 vacuum, access the wheels from the underside of the device by using this guide. There could be a buildup of dust or other foreign objects in the wheel chambers, causing a potential blockage. A complete replacement may not be necessary. The wheels are moderately accessible, but there are several pieces to remove for full access. You will not need to do any difficult steps, but be advised that there are several pieces to keep track of. Be cautious when separating the top of the device from the bottom of the device; the two components are held together by wiring. Before starting the guide, be sure to power off the device and drain any water from the device's water tank.
O que você precisa
Flip the device over to access the bottom panel.
Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
Remove the plastic mop attachment by placing your fingers underneath and prying it up.
Uma outra pessoa concluiu este guia.
