Ir para o conteúdo principal
Yuneec Typhoon H Plus Propeller Replacement
    1. Yuneec Typhoon H Plus Propeller Replacement, Propeller: passo 1, imagem 1 %32
      • Locate the broken propeller and figure out if it is a A-propeller or B-propeller.
      • An A-propeller will have a black button in the center and an A imprinted on the propeller.
      • A B-propeller will have a white button and a B imprinted on the propeller.
      • Though the A and B propellers are different the steps to replace one are the same.
      Pergunte ao FixBot
      Comentar
    2. Yuneec Typhoon H Plus Propeller Replacement: passo 2, imagem 1 %32
      • Press down on the button firmly.
      Pergunte ao FixBot
      Comentar
    3. Yuneec Typhoon H Plus Propeller Replacement: passo 3, imagem 1 %32 Yuneec Typhoon H Plus Propeller Replacement: passo 3, imagem 2 %32
      • Hold the base of the propeller with your pointer finger.
      • Make sure to continue to hold the button down. Rotate the propeller counter-clockwise, holding the base steady.
      • Lift the propeller off the drone.
      Pergunte ao FixBot
      Comentar
Conclusão
Brice Black
Membro desde: 01/23/20
557 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S2-G1, White Winter 2020 Membro de Cal Poly, Team S2-G1, White Winter 2020
CPSU-WHITE-W20S2G1
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 439
