Ir para o conteúdo principal
Yamaha FG-425 Guitar String Replacement
O que você precisa
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: passo 1, imagem 1 %32 Yamaha FG-425 Guitar String Replacement, Guitar String: passo 1, imagem 2 %32 Yamaha FG-425 Guitar String Replacement, Guitar String: passo 1, imagem 3 %32
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: passo 2, imagem 1 %32 Yamaha FG-425 Guitar String Replacement: passo 2, imagem 2 %32
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: passo 3, imagem 1 %32 Yamaha FG-425 Guitar String Replacement: passo 3, imagem 2 %32
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: passo 4, imagem 1 %32 Yamaha FG-425 Guitar String Replacement: passo 4, imagem 2 %32 Yamaha FG-425 Guitar String Replacement: passo 4, imagem 3 %32
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: passo 5, imagem 1 %32 Yamaha FG-425 Guitar String Replacement: passo 5, imagem 2 %32
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: passo 6, imagem 1 %32
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: passo 7, imagem 1 %32
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Nicole Francheska Letigio
Membro desde: 01/18/21
207 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 314
