Ir para o conteúdo principal
YCCTEAM YCC-SW4001 Shoulder Buttons Replacement
O que você precisa
  1. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Front Case: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 2, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 2, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 2, imagem 3 %32
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 4, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 4, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 4, imagem 3 %32
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 5, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 5, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 5, imagem 3 %32
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 6, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 6, imagem 2 %32
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 7, imagem 1 %32
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: passo 8, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: passo 8, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: passo 8, imagem 3 %32
    • Flip over the front cover and remove the four 5.8 mm screws from the rear of the front cover using a Phillips screwdriver.
  9. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 9, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 9, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 9, imagem 3 %32
    • Flip up the ZIF locking flap.
  10. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 10, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 10, imagem 2 %32
    • Disconnect the cable from the ZIF connector using tweezers or by hand.
  11. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 11, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 11, imagem 2 %32
    • Remove the circuit board and shoulder buttons assembly from the front cover.
  12. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 12, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 12, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 12, imagem 3 %32
    • Remove the R button by hand.
  13. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 13, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 13, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 13, imagem 3 %32
    • Remove the L button by hand.
    • Flip the shoulder buttons attachment and look at the metal rods.
  14. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 14, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 14, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 14, imagem 3 %32
    • Remove the metal rod under "ZL" using the small needle nose pliers.
  15. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 15, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 15, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 15, imagem 3 %32
    • Remove the metal rod under "ZR" using small needle nose pliers.
  16. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 16, imagem 1 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 16, imagem 2 %32 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: passo 16, imagem 3 %32
    • Remove the ZL and ZR buttons by hand.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 336
