Introdução
If the YCCTEAM YCC-SW4001's vibration feature is not working as expected, then follow this guide to replace the rumble motors.
The rumble motors are a feature of a controller that vibrates after a certain condition in a game. This condition is different in each game. The intensity of the rumble is fixed, which means it doesn't get more intense or less intense over time. This may be unwanted for some users, so unplugging them could benefit the overall experience.
O que você precisa
Use a Phillips #1 screwdriver to remove the eight 9.15 mm screws that secure the back case.
On the front side, unplug the cables connecting the two rumble motors to the circuit board by gripping each cable and pulling away from the corresponding plug with moderate force.
