Ir para o conteúdo principal
YCCTEAM YCC-SW4001 Battery Replacement
O que você precisa
  1. YCCTEAM YCC-SW4001 Battery Replacement, Front Case: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 Battery Replacement: passo 2, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 2, imagem 2 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 2, imagem 3 %32
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 Battery Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 Battery Replacement: passo 4, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 4, imagem 2 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 4, imagem 3 %32
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 Battery Replacement: passo 5, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 5, imagem 2 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 5, imagem 3 %32
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 Battery Replacement: passo 6, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 6, imagem 2 %32
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 Battery Replacement: passo 7, imagem 1 %32
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 Battery Replacement, Battery: passo 8, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement, Battery: passo 8, imagem 2 %32 YCCTEAM YCC-SW4001 Battery Replacement, Battery: passo 8, imagem 3 %32
    • Remove the two joystick covers by gripping them and pulling them straight upward with moderate force.
  9. YCCTEAM YCC-SW4001 Battery Replacement: passo 9, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 9, imagem 2 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 9, imagem 3 %32
    • Use tweezers to grip the white plastic battery connector. Lift it directly it up and out of its socket.
    • Do not pull on the wires.
    • When replacing the battery, press the plug down into the socket until it snaps into place.
  10. YCCTEAM YCC-SW4001 Battery Replacement: passo 10, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 10, imagem 2 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 10, imagem 3 %32
    • Use a Phillips screwdriver to remove the three 7.5 mm screws that secure the motherboard.
    • Remove the player LEDs from the motherboard.
  11. YCCTEAM YCC-SW4001 Battery Replacement: passo 11, imagem 1 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 11, imagem 2 %32 YCCTEAM YCC-SW4001 Battery Replacement: passo 11, imagem 3 %32
    • Gently lift the motherboard up and out of the controller and set it directly between the grips.
    • Take care not to damage the rumble motor connections.
  12. YCCTEAM YCC-SW4001 Battery Replacement: passo 12, imagem 1 %32
    • Use a spudger to gently lever the battery out of the controller.
    • The battery is attached with adhesive, so gently sever the adhesive around the entirety of the battery as you pry.
    • Take care not to puncture or bend the battery.
    • If your new battery does not come with adhesive, apply new adhesive to secure the battery.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 48
Ao todo: 447
