Ir para o conteúdo principal
YCCTEAM YCC-SW4001 ABXY Buttons Replacement
O que você precisa
  1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Front Case: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 2, imagem 1 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 2, imagem 2 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 2, imagem 3 %32
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 4, imagem 1 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 4, imagem 2 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 4, imagem 3 %32
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 5, imagem 1 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 5, imagem 2 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 5, imagem 3 %32
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 6, imagem 1 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 6, imagem 2 %32
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 7, imagem 1 %32
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: passo 8, imagem 1 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: passo 8, imagem 2 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: passo 8, imagem 3 %32
    • Isolate the front cover.
    • Flip over the front cover and remove the four 5.77 mm screws from the back of the front cover using the Phillips #1 Screwdriver.
  9. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 9, imagem 1 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 9, imagem 2 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 9, imagem 3 %32
    • Lift the circuit board from the front cover to expose the back of the buttons.
  10. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 10, imagem 1 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 10, imagem 2 %32 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: passo 10, imagem 3 %32
    • Remove the rubber caps and the button caps by either dumping them out or taking them out by hand.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 443
