Ir para o conteúdo principal
Xtreme Gaming XG-700 Internal Switch Replacement
O que você precisa
  1. Xtreme Gaming XG-700 Internal Switch Replacement, Switch: passo 1, imagem 1 %32
    • Flip the mouse over and peel off the two feet at the bottom of the mouse.
    • Using a Phillips #000 screwdriver, remove the two 5.6 mm screws.
  2. Xtreme Gaming XG-700 Internal Switch Replacement: passo 2, imagem 1 %32
    • Carefully separate the base of the mouse from the top case as there are ribbon connectors holding the two pieces together.
    • Don't yank or pull the two pieces apart or you will rip the cables.
  3. Xtreme Gaming XG-700 Internal Switch Replacement: passo 3, imagem 1 %32 Xtreme Gaming XG-700 Internal Switch Replacement: passo 3, imagem 2 %32 Xtreme Gaming XG-700 Internal Switch Replacement: passo 3, imagem 3 %32
    • Carefully remove the two cables from their connection point.
    • The top half of the case can be set aside.
  4. Xtreme Gaming XG-700 Internal Switch Replacement: passo 4, imagem 1 %32 Xtreme Gaming XG-700 Internal Switch Replacement: passo 4, imagem 2 %32
    • Using a small plastic spudger, release the four clips from each corner of the board.
    • Gently remove the board out of the case.
    • Don't yank or pull the board off the case. There is one cable connecting the board to the case.
  5. Xtreme Gaming XG-700 Internal Switch Replacement: passo 5, imagem 1 %32
    • Carefully disconnect the ribbon cable from the board.
    • Set aside the case.
  6. Xtreme Gaming XG-700 Internal Switch Replacement: passo 6, imagem 1 %32 Xtreme Gaming XG-700 Internal Switch Replacement: passo 6, imagem 2 %32
    • Flip the motherboard over, and using a soldering iron, desolder the three switch prongs on each side of the switch.
    • Remove the broken switch.
Conclusão
Uma outra pessoa concluiu este guia.
Nam Nguyen
Membro desde: 06/30/22
154 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,173
