Introdução
The front panel is attached to the main case of the camera. It can be removed with a small blue plastic opening tool.
The front panel does not include the lens, but does allow you access to other internal parts of the camera; or, to replace a damaged front panel.
O que você precisa
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
5 outras pessoas executaram este guia.
3Comentários do guia
Where do you get a spare front panel, the small plastic hooks break easily
I would like to know too because i had a crash and i lost the ring that goes around the lens.
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
