Ir para o conteúdo principal
Xiaomi Yi Back Panel Replacement
O que você precisa
    1. Xiaomi Yi Back Panel Replacement, Battery: passo 1, imagem 1 %32 Xiaomi Yi Back Panel Replacement, Battery: passo 1, imagem 2 %32
      • Push the battery door switch to the left.
      • Lift the battery door up.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Yi Back Panel Replacement: passo 2, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 2, imagem 2 %32 Xiaomi Yi Back Panel Replacement: passo 2, imagem 3 %32
      • Lift the battery tab up.
      • Remove the battery by pulling the removal tab.
      Pergunte ao FixBot
      Comentar
    1. Xiaomi Yi Back Panel Replacement, Front Panel: passo 3, imagem 1 %32 Xiaomi Yi Back Panel Replacement, Front Panel: passo 3, imagem 2 %32
      • Introduce the plastic opening tool into any of the sides of the camera.
      • Pry with the plastic opening tool at the seam between the front and the back panel.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Yi Back Panel Replacement: passo 4, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 4, imagem 2 %32 Xiaomi Yi Back Panel Replacement: passo 4, imagem 3 %32
      • Slide prying tool along the seam until front panel is fully separated from the back panel.
      Pergunte ao FixBot
      Comentar
    1. Xiaomi Yi Back Panel Replacement, Back Panel: passo 5, imagem 1 %32 Xiaomi Yi Back Panel Replacement, Back Panel: passo 5, imagem 2 %32
      • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Yi Back Panel Replacement: passo 6, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 6, imagem 2 %32 Xiaomi Yi Back Panel Replacement: passo 6, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
      Pergunte ao FixBot
      Comentar
    3. Xiaomi Yi Back Panel Replacement: passo 7, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 7, imagem 2 %32
      • Remove the motherboard from from the back case by gently pulling on the lens housing.
      • Back panel remains.
      Pergunte ao FixBot
      Comentar
Conclusão
10 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 15-5, Blackwell Fall 2015 Membro de USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Membros
Autoria de 10 guias
2Comentários do guia
Where can I buy back panel for Xiaomi Yi?
matulek - Responder Compartilhar
Where can i buy the back panel replacement ?
Roland Meilleur - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 59
Ao todo: 4,484
