Ir para o conteúdo principal
Xiaomi Mi Pad Front Camera Replacement
O que você precisa
    1. Xiaomi Mi Pad Front Camera  Replacement, Rear Case Assembly: passo 1, imagem 1 %32
      • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Mi Pad Front Camera  Replacement: passo 2, imagem 1 %32 Xiaomi Mi Pad Front Camera  Replacement: passo 2, imagem 2 %32
      • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
      • The back panel has small clips and light adhesive that easily releases from the device.
      Pergunte ao FixBot
      Comentar
    1. Xiaomi Mi Pad Front Camera  Replacement, Front Camera: passo 3, imagem 1 %32 Xiaomi Mi Pad Front Camera  Replacement, Front Camera: passo 3, imagem 2 %32
      • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Mi Pad Front Camera  Replacement: passo 4, imagem 1 %32
      • Remove the upper cover from the device.
      Pergunte ao FixBot
      Comentar
    3. Xiaomi Mi Pad Front Camera  Replacement: passo 5, imagem 1 %32
      • Use a plastic opening tool to gently disconnect the front-facing camera from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Xiaomi Mi Pad Front Camera  Replacement: passo 6, imagem 1 %32
      • Carefully remove the front camera from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Rene Mendoza
Membro desde: 09/03/15
323 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 12-5, Blackwell Fall 2015 Membro de USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Membros
Autoria de 38 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 1,484
