Ir para o conteúdo principal
Xiaomi Mi Note Front camera Replacement
O que você precisa
  1. Xiaomi Mi Note Front camera Replacement, Dual SIM SD Card: passo 1, imagem 1 %32
    • Locate the hole for the Dual SIM SD card on the left side of the phone.
    Pergunte ao FixBot
    Comentar
  2. Xiaomi Mi Note Front camera Replacement: passo 2, imagem 1 %32 Xiaomi Mi Note Front camera Replacement: passo 2, imagem 2 %32
    • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
    Pergunte ao FixBot
    Comentar
  3. Xiaomi Mi Note Front camera Replacement, Battery: passo 3, imagem 1 %32 Xiaomi Mi Note Front camera Replacement, Battery: passo 3, imagem 2 %32
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
    Pergunte ao FixBot
    Comentar
  4. Xiaomi Mi Note Front camera Replacement: passo 4, imagem 1 %32 Xiaomi Mi Note Front camera Replacement: passo 4, imagem 2 %32 Xiaomi Mi Note Front camera Replacement: passo 4, imagem 3 %32
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
    Pergunte ao FixBot
    Comentar
  5. Xiaomi Mi Note Front camera Replacement: passo 5, imagem 1 %32
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Xiaomi Mi Note Front camera Replacement: passo 6, imagem 1 %32 Xiaomi Mi Note Front camera Replacement: passo 6, imagem 2 %32
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
    Pergunte ao FixBot
    Comentar
  7. Xiaomi Mi Note Front camera Replacement, Front camera: passo 7, imagem 1 %32
    • Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Xiaomi Mi Note Front camera Replacement: passo 8, imagem 1 %32 Xiaomi Mi Note Front camera Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
    • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
    • When detaching the ribbon on the left use minimal force to prevent damage.
    Pergunte ao FixBot
    Comentar
  9. Xiaomi Mi Note Front camera Replacement: passo 9, imagem 1 %32 Xiaomi Mi Note Front camera Replacement: passo 9, imagem 2 %32
    • Use a tweezer to lift and remove the motherboard from the frame.
    • Be sure that the Dual SIM card and tray has been removed.
    Pergunte ao FixBot
    Comentar
  10. Xiaomi Mi Note Front camera Replacement: passo 10, imagem 1 %32
    • The front camera is attached to the motherboard by a ribbon, use tweezers to detach it from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-6, Sullivan Fall 2015 Membro de USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Membros
Autoria de 12 guias
1Comentário do guia
Telefonumu 2 hafta önce suya düşürdüm ilk etapta açılmadı ama şimdi açılıyor ama kamera çalışmıyor ön kamera Bir de hoparlörü boğuk çıkıyor tamir etsene
Kaan Guney - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 22
Ao todo: 2,996
