Ir para o conteúdo principal
Xiaomi Mi Note Battery Replacement
O que você precisa
  1. Xiaomi Mi Note Battery Replacement, Battery: passo 1, imagem 1 %32 Xiaomi Mi Note Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
    Pergunte ao FixBot
    Comentar
  2. Xiaomi Mi Note Battery Replacement: passo 2, imagem 1 %32 Xiaomi Mi Note Battery Replacement: passo 2, imagem 2 %32 Xiaomi Mi Note Battery Replacement: passo 2, imagem 3 %32
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
    Pergunte ao FixBot
    Comentar
  3. Xiaomi Mi Note Battery Replacement: passo 3, imagem 1 %32
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Xiaomi Mi Note Battery Replacement: passo 4, imagem 1 %32 Xiaomi Mi Note Battery Replacement: passo 4, imagem 2 %32
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
16 outras pessoas executaram este guia.
Mark Sears
Membro desde: 08/27/15
1.265 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-6, Sullivan Fall 2015 Membro de USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 66
Ao todo: 38,853
