Ir para o conteúdo principal
Xiaomi Mi 9 AMOLED & Digitizer Replacement
O que você precisa
  1. Xiaomi Mi 9 AMOLED & Digitizer Replacement, Rear Glass: passo 1, imagem 1 %32
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 2, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 2, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 2, imagem 3 %32
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 3, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 3, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 4, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 4, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 4, imagem 3 %32
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
    • Be aware of the rear cameras and only insert the tip of the opening pick. As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 5, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 5, imagem 2 %32
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 6, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 6, imagem 2 %32
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
  7. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 7, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 7, imagem 2 %32
    • Carefully lift the rear glass and remove it.
    • Before installing new adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Xiaomi Mi 9 AMOLED & Digitizer Replacement, Motherboard Cover with Charging Coil: passo 8, imagem 1 %32
    • Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
    • There might be tamper proof sticker on some of the screws.
  9. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 9, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 9, imagem 2 %32
    • Insert an opening pick at the top right corner of the motherboard cover.
    • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
  10. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 10, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 10, imagem 2 %32
    • Carefully remove the motherboard cover including the charging coil / NFC antenna.
  11. Xiaomi Mi 9 AMOLED & Digitizer Replacement, Battery Disconnect: passo 11, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement, Battery Disconnect: passo 11, imagem 2 %32
    • Use a spudger to pry up and disconnect the battery flex cable.
  12. Xiaomi Mi 9 AMOLED & Digitizer Replacement, Loudspeaker Unit: passo 12, imagem 1 %32
    • Remove the seven Phillips #00 screws securing the loudspeaker unit:
    • Four silver 3.2 mm long screws
    • Two yellowish 3.8 mm long screws
    • One black 2.8 mm long screw
    • Some screws may be hidden beneath tamper proof stickers.
  13. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 13, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 13, imagem 2 %32
    • Slide an opening pick under the right side of the loudspeaker unit.
    • Twist the opening pick sideways to pry up the loudspeaker unit until you can get a good grip.
  14. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 14, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 14, imagem 2 %32
    • There is still an antenna cable connected to the back of the unit.
    • Carefully lift the loudspeaker unit and hinge it open towards the left side.
  15. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 15, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 15, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to pry off and disconnect the antenna cable from the loudspeaker unit.
    • Remove the loudspeaker unit.
    • Before reassembly check your old loudspeaker for components that might need to be transferred to the replacement part such as the antenna flex cable with its coax connector.
  16. Xiaomi Mi 9 AMOLED & Digitizer Replacement, Battery: passo 16, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement, Battery: passo 16, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement, Battery: passo 16, imagem 3 %32
    Comprar
    • Use a pair of tweezers to peel the black ends of the adhesive tabs off the battery.
  17. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 17, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 17, imagem 2 %32
    Plastic Cards
    $2.99
    Comprar
    • Use a pair of tweezers to pull out the left adhesive tab from underneath the battery.
    • The adhesive tab underneath the battery can rip very easily. Make sure you pull out the tab in a slow and steady motion and in a flat angle. To prevent the adhesive tab from ripping, it's helpfull to twist the strip around the tweezers.
    • In case one of the adhesive tabs rips and it‘s not possible to pull it out completely, you can use isopropyl alcohol or an heated iOpener to loosen the adhesive. After the adhesive is soft enough use a prying tool such as an opening pick or a plastic card to pry out the battery.
  18. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 18, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 18, imagem 2 %32
    • Use a pair of tweezers to pull out the right adhesive tab from underneath the battery.
  19. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 19, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 19, imagem 2 %32
    • Use an opening pick to pry the battery out of its recess until you can get a good grip.
  20. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 20, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 20, imagem 2 %32
    • Remove the battery.
    • Reusing a deformed or bent battery after it has forcefully been removed, is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth before applying new adhesive.
  21. Xiaomi Mi 9 AMOLED & Digitizer Replacement, AMOLED & Digitizer: passo 21, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement, AMOLED & Digitizer: passo 21, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement, AMOLED & Digitizer: passo 21, imagem 3 %32
    Comprar
    • Use a spudger to pry up and disconnect the display flex cable.
    • Use a pair of tweezers to peel the display flex cable off the midframe. It is attached with mild adhesive.
  22. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 22, imagem 1 %32
    • Apply a heated iOpener to the display for two minutes to loosen the adhesive beneath.
    • The adhesive that holds down the screen is fairly strong. You might need to reheat and reapply the iOpener several times to get the adhesive warm enough.
  23. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 23, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 23, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 23, imagem 3 %32
    • You can use a piece of cloth to minimize the phone rocking over the camera bump.
    • Apply a suction handle near the top edge of the phone right under the earpiece speaker.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Use the suction handle to pull up the screen and insert just the tip of an opening pick under the right edge of the speaker recess.
    • Rotate the opening pick sideways to bring the long edge of the pick under the display glass and slide it to the top right corner. Leave it there to prevent the adhesive from resealing.
  24. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 24, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 24, imagem 2 %32
    • Repeat the previous process on the left corner of the speaker recess and slide the long edge of an opening pick to the top left corner of the phone.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  25. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 25, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 25, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 25, imagem 3 %32
    • Slide the long edge of the first opening pick around the top right corner and along the right edge of the phone.
    • Leave the opening pick where the power and volume buttons are located to generate a bigger gap between the midframe and display glass.
    • Insert a third opening pick at the top right edge of the screen. Make sure to slide it underneath the AMOLED and not between the the display glass and panel.
  26. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 26, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 26, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 26, imagem 3 %32
    • Apply more heat if the adhesive becomes hard to cut.
    • Reposition the opening pick above the power and volume buttons so that the tip of the opening pick is placed underneath the display panel too.
    • Slide the opening pick to the bottom right of the phone to cut the adhesive. Leave it there to prevent the adhesive from resealing.
  27. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 27, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 27, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 27, imagem 3 %32
    • Insert a fourth opening pick underneath the display panel at the top left corner of the phone.
    • Slide the opening pick along the side towards and around the bottom left corner of the phone to cut the adhesive.
    • Try not to remove the display all the way yet. The display flex cable is still threaded through the midframe.
  28. Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 28, imagem 1 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 28, imagem 2 %32 Xiaomi Mi 9 AMOLED & Digitizer Replacement: passo 28, imagem 3 %32
    • Slowly separate the screen from the frame and cut any remaining adhesive. Make sure the flex cable is no longer stuck to the frame and carefully thread it through its gap.
    • Remove the screen.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Conclusão
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
21 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
210.026 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
14 comentários
Hat jemand einen Tipp, womit ich das neue Display einklebe?
Marcel - Responder
Doppeltes Klebeband. Gibts auch amazon passgenau oder du bastelt dir selbst wad
schifferyan -
¿Sabe de alguna pagina donde pueda conseguir la pantalla original?
Eva - Responder
il manque la partie ou on enlève la batterie (via les petit scotch. de plus la première étape devait être d’enlever le tiroir pour la carte sim
Gosselin Mathieu - Responder
Bonjour Mathieu, merci de votre attention et de votre remarque. La partie du retrait de la batterie a été ajoutée. Par contre, la carte SIM qui se trouve derrière la carte mère ne dérange pas la procédure. Il n’est donc pas nécessaire de commencer par la retirer. J’espère que vous avez à présent toutes les infos pour effectuer la réparation. Bonne continuation !
Claire Miesch -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 76
Últimos 30 dias: 371
Duração total: 35,930
