Ir para o conteúdo principal
Xiaomi Air 12 Battery Replacement
O que você precisa
    1. Xiaomi Air 12 Battery Replacement, Rear Casing: passo 1, imagem 1 %32
      • Orient the computer so the Xiaomi logo is at the bottom of the device.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Air 12 Battery Replacement: passo 2, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 2, imagem 2 %32 Xiaomi Air 12 Battery Replacement: passo 2, imagem 3 %32
      • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
      Pergunte ao FixBot
      Comentar
    3. Xiaomi Air 12 Battery Replacement: passo 3, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 3, imagem 2 %32
      • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
      Pergunte ao FixBot
      Comentar
    4. Xiaomi Air 12 Battery Replacement: passo 4, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 4, imagem 2 %32 Xiaomi Air 12 Battery Replacement: passo 4, imagem 3 %32
      • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
      • You will hear popping noises as you remove the cover.
      Pergunte ao FixBot
      Comentar
    5. Xiaomi Air 12 Battery Replacement: passo 5, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 5, imagem 2 %32
      • Remove the back of the laptop by gently lifting the casing upwards.
      Pergunte ao FixBot
      Comentar
    1. Xiaomi Air 12 Battery Replacement, SSD: passo 6, imagem 1 %32 Xiaomi Air 12 Battery Replacement, SSD: passo 6, imagem 2 %32
      • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Air 12 Battery Replacement: passo 7, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 7, imagem 2 %32
      • Remove the 1.5mm screw using the JIS #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Xiaomi Air 12 Battery Replacement: passo 8, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 8, imagem 2 %32
      • Lift the SSD up from the device and gently pull the SSD from the laptop.
      Pergunte ao FixBot
      Comentar
    1. Xiaomi Air 12 Battery Replacement, Battery: passo 9, imagem 1 %32
      • Detach the red wire from the tabs on the perimeter of the metal bracket.
      Pergunte ao FixBot
      Comentar
    2. Xiaomi Air 12 Battery Replacement: passo 10, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 10, imagem 2 %32 Xiaomi Air 12 Battery Replacement: passo 10, imagem 3 %32
      • Use a PH1 screwdriver to remove the five 2mm black screws.
      • Remove two silver 1mm JIS #00 screws.
      • There will be clear plastic spacers that come off with the silver screws.
      Pergunte ao FixBot
      Comentar
    3. Xiaomi Air 12 Battery Replacement: passo 11, imagem 1 %32 Xiaomi Air 12 Battery Replacement: passo 11, imagem 2 %32 Xiaomi Air 12 Battery Replacement: passo 11, imagem 3 %32
      • Lift the battery up and pull out from the device.
      • The metal bracket will come out with the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
11 outras pessoas executaram este guia.
Hannah Kwan
Membro desde: 04/18/18
928 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G4, Livingston Spring 2018 Membro de Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 Membros
Autoria de 40 guias
6Comentários do guia
I have a problem, the battery do not really charge, 100% is reach in few minutes, and it works less than 15 minutes on battery. Is anybody have a solution ? Bios update maybe ?
Migwell2 - Responder Compartilhar
I got to pull out my bloated battery…. Though it could work with just the charger on stand by but it did not… Anyone knows where I can purchase new battery? Can't bring it to the shop because of quarantine but need to work from home.
Roma Monica Desunia - Responder Compartilhar
I removed the bloated battery too. It can’t power on properly. The power light just just on and off around every 5 seconds. Is yours the same?
sdot - Responder Compartilhar
after I change the battery it always says plugged in not charge, anyone has the same issue?
Anthony Jethro Lieander - Responder Compartilhar
Hi. There is no page for keyboard replacement so I'm asking my question here: how can I find a keyboard replacement for my mi 12.5 notebook? Only two buttons do not work.
Hamed Mirrezaee - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 26
Últimos 30 dias: 144
Ao todo: 13,340
