Ir para o conteúdo principal
Xelio P900A-BK Battery Replacement
O que você precisa
  1. Xelio P900A-BK Battery Replacement, Battery: passo 1, imagem 1 %32
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: passo 2, imagem 1 %32 Xelio P900A-BK Battery Replacement: passo 2, imagem 2 %32
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: passo 3, imagem 1 %32
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: passo 4, imagem 1 %32 Xelio P900A-BK Battery Replacement: passo 4, imagem 2 %32 Xelio P900A-BK Battery Replacement: passo 4, imagem 3 %32
  5. Xelio P900A-BK Battery Replacement: passo 5, imagem 1 %32 Xelio P900A-BK Battery Replacement: passo 5, imagem 2 %32
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
Conclusão
Marcus Nelson
Membro desde: 03/26/15
307 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-6, Cichon Spring 2015 Membro de UMass Dartmouth, Team 7-6, Cichon Spring 2015
UMASSD-CICHON-S15S7G6
Membros da 3
Autoria de 8 guias
Um comentário
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 342
