Introdução
Use this guide to replace a faulty cooling fan in an Xbox Series X. You can also follow this guide to remove a dusty or dirty fan to clean it out.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Peças
Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Use a T8 Torx driver to remove the two 7.4 mm screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pivot the spudger on the shell and pull up on the bottom of the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.5 mm wide-head screw
Two 8.8 mm screws
Use a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
5 outras pessoas concluíram este guia.
