Ir para o conteúdo principal
Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement
O que você precisa
  1. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: passo 1, imagem 1 %32 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: passo 1, imagem 2 %32 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: passo 1, imagem 3 %32
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: passo 2, imagem 1 %32 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: passo 2, imagem 2 %32 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: passo 2, imagem 3 %32
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: passo 3, imagem 1 %32 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: passo 3, imagem 2 %32 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: passo 3, imagem 3 %32
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
Conclusão
Manuel Haeussermann
Membro desde: 07/13/22
22.747 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.648 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 154
Ao todo: 3,654
