Introdução
Use this guide to replace a damaged or worn-down bumper cover on your Xbox Series X|S Controller (model 1914).
O que você precisa
Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
Remove the left handle cover.
Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
Remove the right handle cover.
Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
Insert the flat end of a spudger under the right USB-C port cover clip.
Pry up with the spudger to release the clip.
Repeat the procedure to release the left clip.
Insert the point of a spudger between the clip on the outer edge of the right bumper and the midframe.
Pry out with the spudger to release the right side of the bumper cover.
Insert the point of a spudger between the clip on the outer edge of the left bumper and the midframe.
Pry out with the spudger to release the left side of the bumper cover.
4 outras pessoas executaram este guia.
Um comentário
The left bumper button broke for me. The plastic post that presses the button just snapped. This helped me replace the bumper. Good guide.
