Ir para o conteúdo principal
Xbox Series S Fan Replacement
O que você precisa
  1. Xbox Series S Fan Replacement, Peel off the sticker coverings: passo 1, imagem 1 %32 Xbox Series S Fan Replacement, Peel off the sticker coverings: passo 1, imagem 2 %32 Xbox Series S Fan Replacement, Peel off the sticker coverings: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
  2. Xbox Series S Fan Replacement, Remove the back panel screws: passo 2, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Fan Replacement, Remove the bottom panel: passo 3, imagem 1 %32 Xbox Series S Fan Replacement, Remove the bottom panel: passo 3, imagem 2 %32 Xbox Series S Fan Replacement, Remove the bottom panel: passo 3, imagem 3 %32
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Fan Replacement, Remove the plastic case screws: passo 4, imagem 1 %32
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Fan Replacement, Remove the plastic case: passo 5, imagem 1 %32 Xbox Series S Fan Replacement, Remove the plastic case: passo 5, imagem 2 %32 Xbox Series S Fan Replacement, Remove the plastic case: passo 5, imagem 3 %32
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Fan Replacement: passo 6, imagem 1 %32 Xbox Series S Fan Replacement: passo 6, imagem 2 %32 Xbox Series S Fan Replacement: passo 6, imagem 3 %32
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  7. Xbox Series S Fan Replacement, Remove the power supply screws: passo 7, imagem 1 %32
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
  8. Xbox Series S Fan Replacement, Remove the upper chassis: passo 8, imagem 1 %32 Xbox Series S Fan Replacement, Remove the upper chassis: passo 8, imagem 2 %32
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
  9. Xbox Series S Fan Replacement, Remove the power supply: passo 9, imagem 1 %32 Xbox Series S Fan Replacement, Remove the power supply: passo 9, imagem 2 %32 Xbox Series S Fan Replacement, Remove the power supply: passo 9, imagem 3 %32
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
  10. Xbox Series S Fan Replacement, Remove the fan screws: passo 10, imagem 1 %32
    • Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
  11. Xbox Series S Fan Replacement, Disconnect the fan: passo 11, imagem 1 %32 Xbox Series S Fan Replacement, Disconnect the fan: passo 11, imagem 2 %32
    • Take care when flipping the chassis over because the fan is now loose.
    • Use your fingers to pull and disconnect the fan connector from its motherboard socket.
    • Take care not to pull on the wires when disconnecting the fan to prevent breaking the connector.
    • This connector may be difficult to remove. A good method to remove it is to shimmy the connector up and out of its socket with a spudger.
    • You may be able to remove this connector without removing the power supply with a pair of needle-nose pliers.
  12. Xbox Series S Fan Replacement, Remove the fan: passo 12, imagem 1 %32 Xbox Series S Fan Replacement, Remove the fan: passo 12, imagem 2 %32
    • Lift the fan straight up to remove it from the motherboard.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
19 outras pessoas executaram este guia.
Robert Boyd
Membro desde: 02/01/21
29.173 Reputação
Autoria de 94 guias
2 comentários
what kind of pin connector does the fan use? i want to see if it’s possible to attach a fan splitter y cable.
Sir Yeeks - Responder
Hi wondering if I’m able to switch out the fan to another fan like a noctua fan but I don’t know what fab size?
bp.guevara87 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 35
Últimos 7 dias: 184
Últimos 30 dias: 777
Duração total: 26,518
