Ir para o conteúdo principal
Xbox Series S Bluetooth Board Replacement
O que você precisa
  1. Xbox Series S Bluetooth Board Replacement, Peel off the sticker coverings: passo 1, imagem 1 %32 Xbox Series S Bluetooth Board Replacement, Peel off the sticker coverings: passo 1, imagem 2 %32 Xbox Series S Bluetooth Board Replacement, Peel off the sticker coverings: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
  2. Xbox Series S Bluetooth Board Replacement, Remove the back panel screws: passo 2, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Bluetooth Board Replacement, Remove the bottom panel: passo 3, imagem 1 %32 Xbox Series S Bluetooth Board Replacement, Remove the bottom panel: passo 3, imagem 2 %32 Xbox Series S Bluetooth Board Replacement, Remove the bottom panel: passo 3, imagem 3 %32
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Bluetooth Board Replacement, Remove the plastic case screws: passo 4, imagem 1 %32
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Bluetooth Board Replacement, Remove the plastic case: passo 5, imagem 1 %32 Xbox Series S Bluetooth Board Replacement, Remove the plastic case: passo 5, imagem 2 %32 Xbox Series S Bluetooth Board Replacement, Remove the plastic case: passo 5, imagem 3 %32
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Bluetooth Board Replacement: passo 6, imagem 1 %32 Xbox Series S Bluetooth Board Replacement: passo 6, imagem 2 %32 Xbox Series S Bluetooth Board Replacement: passo 6, imagem 3 %32
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  7. Xbox Series S Bluetooth Board Replacement, Remove the Bluetooth board: passo 7, imagem 1 %32
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Bluetooth board to the long edge of the chassis.
  8. Xbox Series S Bluetooth Board Replacement: passo 8, imagem 1 %32 Xbox Series S Bluetooth Board Replacement: passo 8, imagem 2 %32 Xbox Series S Bluetooth Board Replacement: passo 8, imagem 3 %32
    • Use a spudger to pry and loosen the Bluetooth board.
    • Do not pry from the bottom or sides of the Bluetooth board as it may bend the connector.
    • Pull the Bluetooth board straight out to disconnect it from the chassis.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Robert Boyd
Membro desde: 02/01/21
29.173 Reputação
Autoria de 94 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 33
Últimos 30 dias: 131
Duração total: 5,192
