Ir para o conteúdo principal
Xbox One X Upper Plastic Case Replacement
O que você precisa
  1. Xbox One X Upper Plastic Case Replacement, Remove the sticker: passo 1, imagem 1 %32 Xbox One X Upper Plastic Case Replacement, Remove the sticker: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
  2. Xbox One X Upper Plastic Case Replacement, Remove the external screws: passo 2, imagem 1 %32
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
  3. Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: passo 3, imagem 1 %32 Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: passo 3, imagem 2 %32
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
  4. Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: passo 4, imagem 1 %32 Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: passo 4, imagem 2 %32
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
  5. Xbox One X Upper Plastic Case Replacement: passo 5, imagem 1 %32 Xbox One X Upper Plastic Case Replacement: passo 5, imagem 2 %32 Xbox One X Upper Plastic Case Replacement: passo 5, imagem 3 %32
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
  6. Xbox One X Upper Plastic Case Replacement: passo 6, imagem 1 %32 Xbox One X Upper Plastic Case Replacement: passo 6, imagem 2 %32
    • Push the upper plastic case down and away from the console to remove it completely.
Conclusão
12 outras pessoas executaram este guia.
Kyle Smith
Membro desde: 02/01/21
44.809 Reputação
Autoria de 123 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 80
Últimos 30 dias: 292
Duração total: 13,595
