Ir para o conteúdo principal
Xbox One Wireless Controller Thumbstick Replacement
O que você precisa
  1. Xbox One Wireless Controller Thumbstick Replacement, Battery Pack: passo 1, imagem 1 %32
    • Remove the battery pack cover.
    • Remove batteries.
    Pergunte ao FixBot
    Comentar
  2. Xbox One Wireless Controller Thumbstick Replacement, Side Handles: passo 2, imagem 1 %32 Xbox One Wireless Controller Thumbstick Replacement, Side Handles: passo 2, imagem 2 %32
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Pergunte ao FixBot
    Comentar
  3. Xbox One Wireless Controller Thumbstick Replacement, Screws: passo 3, imagem 1 %32 Xbox One Wireless Controller Thumbstick Replacement, Screws: passo 3, imagem 2 %32
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Xbox One Wireless Controller Thumbstick Replacement, Backplate: passo 4, imagem 1 %32
    • Remove the backplate.
    Pergunte ao FixBot
    Comentar
  5. Xbox One Wireless Controller Thumbstick Replacement, Faceplate: passo 5, imagem 1 %32
    • Remove the faceplate.
    Pergunte ao FixBot
    Comentar
  6. Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: passo 6, imagem 1 %32 Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: passo 6, imagem 2 %32
    • Remove thumbsticks by pulling them up off their poles.
    Pergunte ao FixBot
    Comentar
Conclusão
205 outras pessoas executaram este guia.
Garrett George
Membro desde: 01/22/15
6.482 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
Autoria de 54 guias
32Comentários do guia
Is there any advice for a controller that has had this repair, but continues to drift? I have done this repair successfully many times, and now i have a controller that (with 2 different replacement parts) continues to drift.
Is there a reset or config I can do?
Jim - Responder Compartilhar
Drift issues are a different problem you would need to solder a new joystick box to fix that this is for loose or damaged thumb sticks
myhero667 - Responder Compartilhar
I used a cotton ball on my Xbox one Elite to fix drifting issues.
ajcroyle - Responder Compartilhar
Does anyone know the correct SKU for the joystick box for the Model 1537 in particular? And any link to purchase it. Thanks
ZuYao - Responder Compartilhar
Can i apply 2 thumbsticks off the xbox 360 controller when i removed them?
Merlijn Fransen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 31
Últimos 7 dias: 192
Últimos 30 dias: 910
Ao todo: 404,228
