Introdução
If you suddenly realize you do not feel vibration from your Xbox One Wireless Controller when appropriate, you may have an issue with the rumble motors inside the controller. The best solution to this problem is to replace the Bumper Rumble motors inside the controller. This is a very difficult process and will require wiring skills such as soldering.
O que você precisa
Remove the battery pack cover.
Remove the two AA batteries.
Carefully remove the sticker or puncture to reveal the screw.
The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller.
Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
Remove the current bumper assembly by pulling them off the plastic cover.
De-solder the soldered joints while holding the red and black wires down on the top motherboard.
6 outras pessoas executaram este guia.
