Ir para o conteúdo principal
Xbox One Stereo Headset Microphone Replacement
O que você precisa
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, imagem 1 %32 Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, imagem 2 %32 Xbox One Stereo Headset Microphone Replacement, Microphone: passo 1, imagem 3 %32
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: passo 2, imagem 1 %32
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: passo 3, imagem 1 %32
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: passo 4, imagem 1 %32 Xbox One Stereo Headset Microphone Replacement: passo 4, imagem 2 %32 Xbox One Stereo Headset Microphone Replacement: passo 4, imagem 3 %32
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: passo 5, imagem 1 %32
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: passo 6, imagem 1 %32
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
Conclusão
4 outras pessoas executaram este guia.
Trevor Steele
Membro desde: 02/01/15
233 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-37, Amido Winter 2015 Membro de Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
Membros da 4
Autoria de 5 guias
9 comentários
Is a replacement microphone available from iFixit?
Scott Minton - Responder
What do you replace the mic with?
Its Me - Responder
They have the microphone for sale
daniel david guerrerogarcia - Responder
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Responder
Any mod to make the cable removable?
kikis.andcream - Responder
Hey guys, the back plate of my mic has fallen off by itself how can I fix it
XteriorFury - Responder
Where can we get the microphone piece from? Is it universal or a specific type?
Oliver - Responder
Anyone know where I can order a replacement mic for my Microsoft Armed forces stereo headset?
thanks
Skyler Bell - Responder
Why doesn’t this guide specify where to purchase the replacement mic? Same goes for the speaker replacement guide, great instructions how to replace but not what to replace them with or where to buy?
BattleBorn - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 24
Duração total: 23,823
