Ir para o conteúdo principal
Xbox One S All Digital Edition Top Metal Shield Replacement
O que você precisa
  1. Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: passo 1, imagem 1 %32 Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: passo 1, imagem 2 %32 Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: passo 1, imagem 3 %32
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Top Metal Shield Replacement: passo 2, imagem 1 %32 Xbox One S All Digital Edition Top Metal Shield Replacement: passo 2, imagem 2 %32
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Top Metal Shield Replacement: passo 3, imagem 1 %32 Xbox One S All Digital Edition Top Metal Shield Replacement: passo 3, imagem 2 %32
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Top Metal Shield Replacement: passo 4, imagem 1 %32
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: passo 5, imagem 1 %32 Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: passo 5, imagem 2 %32
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Top Metal Shield Replacement: passo 6, imagem 1 %32 Xbox One S All Digital Edition Top Metal Shield Replacement: passo 6, imagem 2 %32 Xbox One S All Digital Edition Top Metal Shield Replacement: passo 6, imagem 3 %32
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
Conclusão
3 outras pessoas executaram este guia.
Jules Hajjar
Membro desde: 10/10/19
1.915 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team S12-G6, Regan Fall 2019 Membro de Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Membros
Autoria de 32 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 33
Ao todo: 1,263
