Ir para o conteúdo principal
Xbox One Motherboard Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Xbox One Motherboard Replacement, Side Vent: passo 1, imagem 1 %32 Xbox One Motherboard Replacement, Side Vent: passo 1, imagem 2 %32 Xbox One Motherboard Replacement, Side Vent: passo 1, imagem 3 %32
    • With a plastic opening tool, pry the side vent from the console.
    • Start from the back edge and work towards the front of the console.
  2. Xbox One Motherboard Replacement, Wi-Fi Board: passo 2, imagem 1 %32 Xbox One Motherboard Replacement, Wi-Fi Board: passo 2, imagem 2 %32
    • Slide the black angled tab behind the silver button toward the back of the console and set it aside.
  3. Xbox One Motherboard Replacement: passo 3, imagem 1 %32 Xbox One Motherboard Replacement: passo 3, imagem 2 %32 Xbox One Motherboard Replacement: passo 3, imagem 3 %32
    • Rotate the Xbox and remove the warranty sticker from the back. Removing this seal and opening the case of the Xbox voids your warranty with Microsoft.
    • Use a plastic opening tool on the back to pry the top of the case from the bottom. Use an up and out motion to dislodge the clips. There are multiple clips to release on the back and two on the sides.
    • This step may take up more time than the others, keep prying with the plastic opening tool and when you release one clip, wedge something underneath it so it doesn't close again.
  4. Xbox One Motherboard Replacement: passo 4, imagem 1 %32 Xbox One Motherboard Replacement: passo 4, imagem 2 %32
    • Carefully lift the top of the case, note that there is a wire connecting the front panel to the motherboard. Take care not to break this.
    • Using a spudger, release the ribbon wire from the front panel.
    • The top case is now free, set it aside.
  5. Xbox One Motherboard Replacement: passo 5, imagem 1 %32 Xbox One Motherboard Replacement: passo 5, imagem 2 %32 Xbox One Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the speaker by squeezing the the tab on the black plastic mounting piece and lifting it up.
    • Carefully unplug the connector from the green front panel board.
    • The speaker is now free, set it aside.
  6. Xbox One Motherboard Replacement: passo 6, imagem 1 %32 Xbox One Motherboard Replacement: passo 6, imagem 2 %32
    • Unscrew the two 8.2mm T-9 screws securing the Wi-Fi board to the chassis.
    • Using the spudger, gently lift the antenna connector from the Wi-Fi board.
  7. Xbox One Motherboard Replacement: passo 7, imagem 1 %32 Xbox One Motherboard Replacement: passo 7, imagem 2 %32
    • Using a spudger and a motion similar to the previous step, gently lift the antenna connector from the green board on the front.
    • Carefully pull out the clips securing the antenna wire to the chassis, releasing the wire.
  8. Xbox One Motherboard Replacement: passo 8, imagem 1 %32
    • Carefully pull the Wi-Fi board straight up to release it from the chassis. The Wi-Fi board is now free.
  9. Xbox One Motherboard Replacement, Optical/Disc Drive: passo 9, imagem 1 %32 Xbox One Motherboard Replacement, Optical/Disc Drive: passo 9, imagem 2 %32
    • Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
  10. Xbox One Motherboard Replacement: passo 10, imagem 1 %32 Xbox One Motherboard Replacement: passo 10, imagem 2 %32 Xbox One Motherboard Replacement: passo 10, imagem 3 %32
    • Lift the chassis top, being careful not to break the wire connecting the chassis top to the motherboard.
    • Unplug the connector labeled 3 on the motherboard by gently pulling up.
    • The chassis top is now free, set it aside.
  11. Xbox One Motherboard Replacement: passo 11, imagem 1 %32 Xbox One Motherboard Replacement: passo 11, imagem 2 %32 Xbox One Motherboard Replacement: passo 11, imagem 3 %32
    • Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
    • Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • The optical drive is now free, lift it from the chassis and set it aside.
  12. Xbox One Motherboard Replacement, Hard Drive: passo 12, imagem 1 %32 Xbox One Motherboard Replacement, Hard Drive: passo 12, imagem 2 %32
    • Unplug the red wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • Unplug the multi-colored wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • The hard drive is now free, remove it from the chassis by lifting straight up. Set it aside.
  13. Xbox One Motherboard Replacement, Motherboard: passo 13, imagem 1 %32
    • Turn the chassis upside down.
    • Remove the four black 9.5mm T-9 screws labeled A1, A2, A3, and A4.
    • Remove the four grey 11.0mm T-9 screws labeled B1, B2, B3, and B4.
  14. Xbox One Motherboard Replacement: passo 14, imagem 1 %32 Xbox One Motherboard Replacement: passo 14, imagem 2 %32
    • Remove the three 9.5mm T-9 screws holding the front board onto the metal chassis.
    • Remove the single 8.2mm T-9 screw holding the white standoff to the metal chassis.
  15. Xbox One Motherboard Replacement: passo 15, imagem 1 %32 Xbox One Motherboard Replacement: passo 15, imagem 2 %32 Xbox One Motherboard Replacement: passo 15, imagem 3 %32
    • Remove the two black standoffs by squeezing the clips securing them to the metal chassis and lifting up.
    • Remove the white standoff.
    • Unplug the front panel board from the chassis. The board is now free, set it aside.
  16. Xbox One Motherboard Replacement: passo 16, imagem 1 %32
    • Unplug the wire that connects the fan to the motherboard by gently pulling it up.
  17. Xbox One Motherboard Replacement: passo 17, imagem 1 %32
    • Carefully turn the chassis back over. Grasp the motherboard or the fan and lift the assembly free with the fan and heat sink attached. Set the bottom of the chassis aside.
  18. Xbox One Motherboard Replacement: passo 18, imagem 1 %32 Xbox One Motherboard Replacement: passo 18, imagem 2 %32
    • Carefully turn the motherboard and fan over so that the fan is facedown.
    • Firmly wedge the tweezers or a small flathead screwdriver under the edge of the X-shaped spring and lift to release the spring.
    • The X-shaped spring may be stiff and require considerable force to release. Probe around, some arms may be easier than others.
    • Lift the spring free of the pegs and set aside.
  19. Xbox One Motherboard Replacement: passo 19, imagem 1 %32
    • Lift the motherboard free of the fan and heat sink and set aside.
    • Clean off and replace the white heat paste with the help of this guide.
    • Remember to orient the heat sink and fan so they are flush with the right side of the motherboard.
Conclusão
8 outras pessoas executaram este guia.
Gwendolyn Church
Membro desde: 01/27/14
1.500 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 6-22, Maness Winter 2014 Membro de Cal Poly, Team 6-22, Maness Winter 2014
CPSU-MANESS-W14S6G22
Membros da 4
Autoria de 11 guias
Um comentário
Thank you very much, your time, effort, and consideration is very much appreciated. Kudos also for the detailed illustrations it lends a level of professionalism not found in many black and white tech guides.
Christopher_the_Welder - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 48,131
